Acer Iconia One 7 — это планшет, выпущенный в апреле 2014 года. Iconia One 7 представляет собой компактное устройство для мультимедийных развлечений. Благодаря дисплею, который больше, чем у фаблета, отличающемуся четкостью и красочностью, вы получаете быстрый отклик и длительное время автономной работы. Мы также включили платформу Kids Center с множеством интересного детского контента, который могут контролировать родители.
black screen - can't use it.
hello everyone,
I just needed some help with my Acer Iconia one 7 B1-770. I hit the display brightness/darkness at its minimum and found out I can't see nothing at all. I thought there might be issues with low battery but when I pressed the volume, I could hear any sound. Unfortunately, I cannot use my tablet anymore.
Does anyone could help me how to fix this issue??please.
Thanks & God bless.
Это хороший вопрос?
Счет 1
2 Комментариев:
Hello, have you tried a factory reset? Follow these steps:
1. Power off the tablet.
2. Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3. While holding the Volume up button, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4. Once the tablet screen turns on, stop holding the buttons.
5. On the Android system recovery screen, select wipe data/factory reset. Use the Volume up and Volume down keys to navigate through the menus and use the Power button to select the desired option.
6. When prompted to "Confirm wipe of all user data", select Yes -- delete all user data.
7. Select reboot system now.
из
My acer 10 tablet was stuck in black screen after disabling the boot from boot option properties. didn't start up the windows after turning it on.
из
Добавить комментарий
2 Ответов
I had a friend bring this issue to me…
turns out the brightness was just down to zero..
so pull down from the top of the tablet twice.
then about 1 and a half centimeters down just try to use your finger and catch the brightness slider and slide it to the right again and voila… working again.
Был ли этот ответ полезен?
Счет 0
How to fix my acer ipad black screen with grey lines
Счет 0
Добавьте свой ответ
Renalie буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 18
За все время: 5,500
