Why my lenovo phone doesnt charge when its on?
my lenovo phone A7010 charge when its off while it doesnt charge when its on plz help me to solve this problem
Это хороший вопрос?
Это хороший вопрос?
Hi,
What is the model number of the phone?
Have you checked that the charger is either the correct one for your phone and if it is have you tried using another compatible charger to see if the first one is faulty and is not supplying enough current. The DC current output value of the charger should be printed on it. I'm guessing that the value should be around 1000 mA.
If you are using a USB port to charge your phone, as it can supply only 500mA maximum, it will charge the phone but cannot charge and run the phone. The best that it can do is maintain the battery at its' current level.
Был ли этот ответ полезен?
i use original charge my phone is lenovo A701048 its charge when its off only and the battery ca full but when i turned on the battery doesnt charge when i put on charge
Hi, can you try a different charger that is compatible with the phone? it should have a 1000mA (1A) output
i try different charger but its not charge problem
Hi, You are not alone with this problem. Have you checked that you have the latest firmware for the phone installed? Sorry I cannot be of more help.
Hi my Lenovo phone is not charging when I plug it in the red light is on but you are not seeing the the lighting sign but it would reach 83%precent and cut of please tell me how to make my Lenovo smartphone start back to charged to its normal compactity.
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 1,750
2 Комментариев
no its original charge lenovo model A701048 it only charge when its off
из zizozidane94
I have a Lenovo mobile phone and it won't charge and l have tried different charges and usb cables but still won't work. When l charge it it shows 0% and it shows the red arrow to show that it's charging but it doesn't charge.
из tshumabelinda
