What can I do if my daughter wasted water on it?
My daughter placed a cup on top of the laptop. She didn't know it had a hole in it and the soda can out. It works but nothing is on the screen. What can I do?
Это хороший вопрос?
Это хороший вопрос?
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the laptop's operating design and could damage the components.
First do not turn on your laptop and then you need to remove the battery as soon as possible from the laptop to minimize further damage.''
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to the Ifixit guide on how to dis-assemble your laptop.
Hopefully after you have done all this the laptop might possibly work correctly again.
If this process seems too daunting, take your laptop to a reputable, professional computer repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
Thanks so much. This information was quite helpful
it easy pull out the motherboard remove the cpu every thing fan brush the mb with alcohol and let it dry
then test
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 117
