Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
Tablet will not charge
Cannot turn my tablet on and it will not charge so i cannot turn it on no battery life
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Samsung have issue if your battery is to week to charge . To fix this all you need to do is disconnect the battery and then reconnect then hook it to your charger and charge it . This guide will help with opening the tablet.
Samsung Galaxy Tab 7.0 Battery Replacement
Skip step 10 as your not actually going to remove the battery. Hope this helps
Был ли этот ответ полезен?
Счет 3
Your charging Port might be bad try to replace it.
Счет 1
Добавьте свой ответ
mmwhite0811 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 210
