Фотокамера Canon ELPH Z3 была выпущена в Соединенных Штатах в марте 2002 года.
Why doesn't my camera's flash work?
I was trying to take a picture of something that is in a dark background so I tried to use the flash feature on my camera. However, despite adjusting the setting to "flash on" the camera failed to produce a flash for the picture. What may be causing this issue?
Это хороший вопрос?
Счет 0
1 Комментарий
Student question
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
This issue is quite common in some cameras and the solutions can range from simple to pretty complex. Sometimes the reason a camera's flash will not work is because the battery is already running low to the point where the camera can no longer produce a flash. To resolve this all you would need to do is replace the batteries. If that is not the case and your flash is still not working, then there may be a defective flash circuit in which you will need to plan out an exchange with the company you have purchased the camera if it is still under warranty. Hope this helps!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Nathan Barros буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 21
За все время: 552
