Printer head jammed & wont move
I keep getting an error code of 3527, this happened after we had a power outage. The printer head will not return to centre of the track when you open the door to replace any inks?
Это хороший вопрос?
Это хороший вопрос?
Here's a video on fixing the 3527 error code:
https://www.youtube.com/watch?v=AEvyn9QY...
If cleaning the old ink up doesn't fix it, go here and run through Kodaks steps:
Был ли этот ответ полезен?
this is the wrong printer mine is aio printer had i quite a few years and have hardley used it iust be 5 times in the last 20 years as i did not need to print off then now everything you buy on the computer needs printing off
probably alittle late for alowe5 but for others the ink has dried from non-use . you need to clean printhead with warm water or alcohol . follow YouTube video instructions for cleaning printheads then do maintenance for cleaning ink cartridges. you may have to repeat process. Calibrate and do test page.
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 23
За всё время: 7,146
1 Комментарий
The answer did not solve anything
из thetattams
