Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179вопросов Показать все
were is the crankshaft sensor located
i have a 1999 plymouth voyger2.4l dohc i cant locate the crankshaft sensor
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Chrysler 2.4 crankshaft position sensor is bolted in lower engine block, behind the engine (engine side facing the vehicle's firewall) look above the oil filter adapter from under car. Crank sensor held/secured by a bolt, remove bolt and sensor will come out with a little pull/twist force. Links below show the location and how to test crank sensor. Good luck.
https://www.youtube.com/watch?v=TA3IEevw...
http://troubleshootmyvehicle.com/chrysle...
Был ли этот ответ полезен?
Оценка 3
I got a doge 2006 caravan 3.3 where my crank shift seneror at
Оценка 0
Добавьте свой ответ
lamonj777 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 57
За всё время: 5,593
