Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630вопросов Показать все
torn ribbon cable on ipad (help!)
i have been fixing iphones, ipods, ipads, etc for some time now. I mainly focus on screen repairs. While removing the glass from the ipad mini I tore a cable in the top right corner near the rear view camera. Been searching online to find out what i tore and cant seem to find it so I came here seeking help. I can see that there are 2 solder points on the ribbon cable and i'm very tempted to soldering it but figured i would find out what it is before doing it. Please help asap would be great. thank you. below is a picture of the torn cable.
i'm not sure what cable this is i have been searching online can't seem to find what it is. picture [IMG]http://i65.tinypic.com/2mr8f1c.png[/IMG]
Это хороший вопрос?
Оценка 2
3 Комментариев
your pictures arn't loading try this
Adding images to an existing question
из
is that better sir? sorry @jimfixer
из
before i had the ipad on and the screen was unresponsive. that may have been becuase the screen wasnt plugged in along with the digitizer? idk @tomchai
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
If it's connected through a RF connector, it's an antenna, either for GPS or for cellular.
If it's a ZIF connector, it's the prox sensor, which is only used to shunt RF TX power to satisfy SAR regulations, in other words, useless.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
So do you think i should solder it or just say f it and leave it? lol
@tomchai
из
Добавьте свой ответ
omegaxprime98 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 496
