Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591вопросов Показать все
Is this hinge a problem or not?
macbook pro late 2011 13 i nch
today i found out this : https://www.youtube.com/watch?v=nkWJ_T5I...
is this a problem? i looked inside i saw the hinde rod move back and forth
the hinge is stil steady tho at all angles the screen doesnt drop (the magneets pull it down tho when super close)
only thing is when i move it from when its almost close position it makes a slight noice but nothing anoying since that position isnt used alot
should i replace the hinge or not?
does this involve removing the glass? my glass panel does need a replacement so that can be a combined repair if needed
if wanted i can shoot a inside video tomorow
Это хороший вопрос?
Оценка 0
2 Комментариев
ok wil this fix it? i wil take it apart tomorow to paint the under site i wil take a look
из
Paint? just how beat up is his machine? How about a hard case?
http://www.ebay.com/itm/262237889185?_tr...
из
Добавить комментарий
1 ответ
Выбранное решение
See step #13 of this guide. Put it in place and tighten the screws.
MacBook Pro 13" Unibody Late 2011 Display Replacement
Remember, "if it ain't broke, don't fix it".
Был ли этот ответ полезен?
Оценка 4
Добавьте свой ответ
raymond1212 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 139
