MacBook Pro 13" Unibody Late 2011 Display Replacement
Выберете то, что вам нужно
    1. MacBook Pro 13" Unibody Late 2011 Display Replacement, Lower Case: шаг 1, изображение 1 из 1
      • Remove the following ten screws:
      • Three 14.4 mm Phillips #00 screws
      • Three 3.5 mm Phillips #00 screws
      • Four 3.5 mm shouldered Phillips #00 screws
      • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 2, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 2, изображение 2 из 2
      • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
      • Remove the lower case.
      Спросите у FixBot
    1. MacBook Pro 13" Unibody Late 2011 Display Replacement, Battery Connection: шаг 3, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Display Replacement, Battery Connection: шаг 3, изображение 2 из 2
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
      Спросите у FixBot
    2. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 4, изображение 1 из 1
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      Спросите у FixBot
    1. MacBook Pro 13" Unibody Late 2011 Display Replacement, AirPort/Bluetooth Assembly: шаг 5, изображение 1 из 1
      • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
      Спросите у FixBot
    2. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 6, изображение 1 из 1
      • Carefully pull the camera cable out of its socket on the logic board.
      • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
      Спросите у FixBot
    3. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 7, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 7, изображение 2 из 2
      • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
      • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
      Спросите у FixBot
    4. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 8, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 8, изображение 2 из 2
      • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
      • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
      Спросите у FixBot
    5. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 9, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 9, изображение 2 из 2
      • Using the method described in the last step, disconnect the remaining three antenna connectors.
      • De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
      Спросите у FixBot
    6. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 10, изображение 1 из 1
      • Remove the following five screws:
      • Two 10.3 mm Phillips screws
      • Two 3.1 mm Phillips screws
      • One 5 mm Phillips screw
      Спросите у FixBot
    7. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 11, изображение 1 из 1
      • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
      Спросите у FixBot
    8. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 12, изображение 1 из 1
      • Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
      Спросите у FixBot
    1. MacBook Pro 13" Unibody Late 2011 Display Replacement, Display: шаг 13, изображение 1 из 1
      • Remove two of the three 6 mm T8 Torx screws securing the right side of the display to the upper case.
      • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
      Спросите у FixBot
    2. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 14, изображение 1 из 3 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 14, изображение 2 из 3 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 14, изображение 3 из 3
      • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      Спросите у FixBot
    3. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 15, изображение 1 из 2 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 15, изображение 2 из 2
      • Remove the following two screws:
      • One 8.6 mm Phillips screw
      • One 5.5 mm Phillips screw
      • Remove the display data cable retainer from the upper case.
      Спросите у FixBot
    4. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 16, изображение 1 из 1
      • Remove the piece of foam tape covering the display screws near the MagSafe DC-In board.
      Спросите у FixBot
    5. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 17, изображение 1 из 1
      • Remove two of the three 6 mm T8 Torx screws securing the left side of the display to the upper case.
      Спросите у FixBot
    6. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 18, изображение 1 из 1
      • Open your MacBook Pro so the display is perpendicular to the upper case.
      • Place your opened MacBook Pro on a table as pictured.
      • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
      Спросите у FixBot
    7. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 19, изображение 1 из 1
      • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
      • Remove the last remaining T8 Torx screw securing the display to the upper case.
      Спросите у FixBot
    8. MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 20, изображение 1 из 3 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 20, изображение 2 из 3 MacBook Pro 13" Unibody Late 2011 Display Replacement: шаг 20, изображение 3 из 3
      • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
      • Rotate the display slightly away from the upper case.
      • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
      Спросите у FixBot
Заключение
85 человек успешно провели ремонт по этому руководству.
Phillip Takahashi
Участник с: 08/22/11
87 929 Репутация
Автор 87 руководств
8 Комментарии к руководству
Step 18 and 19 is easier if you place the bottom keyboard down, with the display hanging over the edge of a table. This stabilizes the bottom assembly, making teardown and reassembly easier for one person
pedsurgkb - Ответить Поделиться
Fantastic tip - I placed it in front of me so the display rested on my thighs while the base was flat on the table - very safe, no fear of dropping/slipping.
Annette - Ответить Поделиться
Thank you Phillip for providing this Guide. I used it to replace a bad LCD assembly after a water spill damaged it. The last Step 20 is very difficult. I had the worst time trying to separate the two parts after I removed the final Torex screw. It took a while, trying different angles, but I finally got it. Putting in the new one was a trivial exercise...
fasthans - Ответить Поделиться
Phillip, thank you so much for this excellent guide. I have no technical background at all but I found it very easy to use - and it saved me hundreds of dollars on a professional repair job. Keep up the good work!
Simon Mundy - Ответить Поделиться
Thank you so much for going to the effort to explain the steps. It worked out perfect. I work as a Lean Engineer developing Standard Work, which is exactly what you have done. I couldnt have done it any better. Thank you if you ever come to Ireland I owe you a pint :)
Noel Kelly - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 30
За последние 30 дней: 213
За всё время: 101,342
