Power up without internal keyboard
Hi,
I recently spilled liquid on my MacBook Pro 15" Unibody Mid 2009. It will only turn on if I disconnect the keyboard ZIF connector. Too bad the power button is part of the broken keyboard. Is there any way to "jump start" that model?
For older and newer MBPs I have found information regarding how to do that (always shorting to pads on the logic board). Where are those pads on the logic board of my model?
Best Benjamin
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Выбранное решение
See this
Answer for a 17" machine. Your solution will be similar look for the description power button - you may need a magnifying glass.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Thanks. For the pre-unibody MBPs this task was quite easy. But the newer models have no markings on the PCB.
из
Добавьте свой ответ
Benjamin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 5,992
