ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
ΠŸΡ€ΠΈΡΠΎΠ΅Π΄ΠΈΠ½ΡΠΉΡΡ ΠΊ сообщСству Ρ€Π΅ΠΌΠΎΠ½Ρ‚Π½ΠΈΠΊΠΎΠ² - Π‘ΠΎΠ·Π΄Π°ΠΉ Π°ΠΊΠΊΠ°ΡƒΠ½Ρ‚
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
Battery is completely dead?
Hi
I have an iPad Air LTE, and before 6 months ago it died.
Before it died, the iPad didn't charge and it stopped working in the middle on restore. (Error 14, 4014, 4013)
Black screen, no backlight.
Now I'm trying to fix it.
I pulled up the battery and check it voltmeter. On the display is was 0.01v and sometimes 0.03v.
My question is
How I can make sure the problem here is with the battery? Maybe the logic board is dead too?
ΠžΡ‚Π²Π΅Ρ‚ Π½Π° этот вопрос Π£ мСня Ρ‚Π° ΠΆΠ΅ ΠΏΡ€ΠΎΠ±Π»Π΅ΠΌΠ°
Π­Ρ‚ΠΎ Ρ…ΠΎΡ€ΠΎΡˆΠΈΠΉ вопрос?
Π‘Ρ‡Π΅Ρ‚ 0
1 ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
Anyone?......
ΠΈΠ·
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
1 ΠΎΡ‚Π²Π΅Ρ‚
НаиболСС ΠΏΠΎΠ»Π΅Π·Π½Ρ‹ΠΉ ΠΎΡ‚Π²Π΅Ρ‚
if the battery is reading less than 0.5V then the battery is 95% likely toast. That being said, i would try using a 5-10V power supply, and excite it. perhapse able to get it charging. but likely needs replacing.
HOWEVER, there is a possibility of other failures as well.
Π‘Ρ‹Π» Π»ΠΈ этот ΠΎΡ‚Π²Π΅Ρ‚ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
Π‘Ρ‡Π΅Ρ‚ 1
4 ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²:
Do you know how I can connect my iPad to the power without battery?
ΠΈΠ·
you would need a Variable power supply and a battery adapter for that specific device.
a battery adapter takes from the variable power supply, and distributes it in the same form a battery does. This is not something i know where to access, as my franchise HQ supplies them when i bought into the company
ΠΈΠ·
I have found this on iTunes logs
[05:28:04.0964] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[05:28:09.0951] AppleDevice::GetDeviceID: failed for iBoot
it means something??
ΠΈΠ·
the baseband chip processes your cellular signal. if you have a WiFi only model, it would make sense that it not be present. if you have a cellular model, there is a posability that the celular signal will not function.
ΠΈΠ·
Π”ΠΎΠ±Π°Π²ΡŒΡ‚Π΅ свой ΠΎΡ‚Π²Π΅Ρ‚
nir Π±ΡƒΠ΄Ρƒ Π²Π΅Ρ‡Π½ΠΎ Π±Π»Π°Π³ΠΎΠ΄Π°Ρ€Π΅Π½.
Бтатистика просмотров:
Π—Π° послСдниС 24 часов: 0
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 1
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 6
Π—Π° всё врСмя: 563
