Color verticle lines over entire scrteen/picture
color lines over entire screen
actual picture is visable
Это хороший вопрос?
Это хороший вопрос?
That is indicative of a bad timing control board. It could also be the panel, especially if you are able to make some of the lines come and go by squeezing the top, or bottom, of the set.
Был ли этот ответ полезен?
I have 4 inch wide vertical line on middle of TV. Picture around it is fine. Any help?
I have same problem but vertical lines initiated from right side of screen where my 2.5 yr old son hit the screen with his bare hands and then the lines spread out and covered full screen. Below are images for model and screen. Any help on this please? Thanks in advance everyone.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 142
Have you tried a different cable?
из Eric
jjllhh what make and model is your TV? Post some images of your screen with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see.
из oldturkey03
