7,9-дюймовый планшет на базе Android, выпущенный компанией Acer в 2013 году.
Won't charge when plugged in
The power cable will not stay plugged in. When it is in it won't charge .
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
katyro69 , Either the cable or charge port may be damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix, it is probably a damaged/loose port that will have to be repaired/replaced. This is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
Замена материнской платы Acer Iconia A1-810
https://www.youtube.com/watch?v=m-_v-JkN...
http://www.ebay.com/itm/Micro-USB-Tablet...
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
katyro69 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 3,283
