Asus Zenbook UX31A — это ноутбук, выпущенный в июне 2012 года. Он входит в линейку ультрабуков Asus. Устройство оснащено процессором Intel Core i7 третьего поколения и IPS-дисплеем с разрешением Full HD.
Asus Zenbook CMOS problem
MODEL: UX31A NOTEBOOK PC
WINDOWS 8
Okay so the laptop cuts on by power button. System comes on but for some reason goes to Administration password screen with the blue window then me not knowing Administration password I have open the laptop took out the CMOS battery which is also bios chip, but in the process of when I opened it I couldn't find the silver coin looking CMOS battery therefore having to disconnect the KTS battery which is the CMOS and Bios in one. After doing so and cutting back it still once again is cutting on with the power power button but still automatically goes right to Adiministration password with the blue window. Hitting the power button does not turn off the laptop it seems like it's being put in sleep or hibernation mode and pressing the power button on the computer actually held the power button for 4 seconds and still again did not cut off. My question is can I fix it by taking out the ram just get a new kts battery ??
Update (03/28/2017)
-Power button works - Soon as pressing power button once with no hesitation computer automatically comes to this screen -Never has it loaded anything besides this screen, since the problem first occurred -pushed power button once; fan turned off, but screen seems to be in sleep mode or hibernation mode -Held power button for about 4 seconds released screen just appeared back on with BLUE BOX
FORGOT PASSWORD
MODEL # for ASUS brand
-20MINS to unscrew the screws, this is what was presented ONCE IN ! -Carefully lifted yellow tape then detached battery chip that was connected to the motherboard
Battery once detached from laptop
Battery does look a little damaged ?? :( Seems very fragile
Located this battery, wasn't too hard to find due to it being under the main battery
#1
-Took KTS battery out, waited almost about an hour before plugging both batteries back in
#2-Took KTS battery out (never put back in) -Did replace first battery back in
After doing so, I still once again got this %&$@#+! SCREEN !!!!
Это хороший вопрос?
Счет 0
1 Комментарий
Could you please better explain what the problem is? With full punctuation​ and grammar, please?
из Поделиться
Добавить комментарий
2 Ответов
Выбранное решение
Post a picture of this.
However to answer your question, if this is a CMOS password it is asking for, then no. You need to search for an HP backdoor password or pay for one on Ebay.
If this is a Windows administrator password, there are ways to get in. The easiest is using a Windows 8 repair USB.
Был ли этот ответ полезен?
Счет 2
4 Комментариев:
I updated with Pictures.
из Поделиться
Yes, this is a CMOS password. On modern computers, you can't simply reset by pulling out the battery.
try this video https://www.youtube.com/watch?v=oC3B-8P8...
из Поделиться
Thanks for the video, but what did he enter in the "Enter Password" section to get to the settings ???
из Поделиться
So he just was demonstrating a user password he set that showed an administrator password was locking the computer.
The way to get rid of it is go into Windows. Set the date exactly as the video has it. Go back to that admin password screen and hit ALT+R and enter that other password.
из Поделиться
Hi Brianna,
You were almost there!
Near the connector for the battery marked "KTS" are two contact pins next to a label J2001.
What you need to do is to short them by connecting the two points. You can do this using a small flat-head screwdriver.
1. Locate the two J2001 contact points
2. Hold a flat-head screwdriver over the two points
3. Hold the screwdriver in place and connect the power
The laptop should turn on and remove the power password.
It might take you a few times to do this correctly.
Here's an illustration from a similar laptop. (As your images are already annotated)
Счет 1
Добавьте свой ответ
Brianna Bennett буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 30
За все время: 12,633
