Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Вопросов 20 Показать все
Repair damage- help identify part needed
Have an iPad mini retina att model, while removing the digitizer for a repair a cable going to the cell antena area was severed, can someone help me identify the part needed as well as a reputable source ? See link for image https://drive.google.com/open?id=0B8JUkQ...
Update (04/12/2017)
Sorry about that, tried to post from a mobile and was unable to add a photo here is the photo, thanks for the help.
Это хороший вопрос?
Оценка 0
2 Комментариев
Nicholas, you'll have to clear your link "You need permission" if you want anyone to look at it. You should consider posting your images with your question by using this guide Adding images to an existing question
из
Repost you picture using something different so we can give your a proper answer. Thanks
из
Добавить комментарий
Ответов (1)
Выбранное решение
That is the upper right antenna. You can find it here.
Follow this guide(the antenna is specifically addressed on steps 71-73)
Replace a right cellular antenna compatible with the model A1454, A1455, A1490 1st or 2nd generation iPad mini tablet. Изображение
Продукт
iPad mini & mini 2 Right Cellular Antenna
$9.99
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Thanks for the quick answer and part source !
из
Добавьте свой ответ
Nicholas будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 90
