Black screen- What's the problem
My laptop will turn on but there is no display on the screen. I tried turning it off and back on but I had the same issue. What should I do to fix this issue?
Это хороший вопрос?
Это хороший вопрос?
There could be a number of things wrong with your laptop to cause this, it will either be a software or a hardware issue. If you feel capable you can take it apart and check that everything is plugged in right and try again. If that doesn't help you should probably take it in to be looked at.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За все время: 448
