Repair guides and support for tablets manufactured by ProScan.
will a crack in the scren stop the touch screen option
I stepped on my Proscan PLT8802G and cracked the screen. There are 2 cracks and they start in the same place , right above the jack where you plug the key board in. 1 crack goes to one side and the other one goes to the other side. I can turn it on and it charges but that is all. The key board does not work and the touch screen option does not work. When I touch the screen I can see the screen gets darker where I'm touching it but nothing gets activated. What can I do to fix this Please and Thank you very much
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
Sounds like you broke the digitizer . This guide will help you through the repair process
ProScan PLT7223G Screen Replacement
You can find screens on ebay and amazon you need to be more specific with the model if Im to direct you to them . Hope this helps
Был ли этот ответ полезен?
Счет 3
Yes, very helpful. I have a PROSCAN 8802G Tablet with a cracked screen. And the touch screen is not working.
I believe the digitizer is gone, so I need to replace the screen. Where to find the screen is a big question.
Счет 0
Добавьте свой ответ
Dorothy Davis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 430
