4-дюймовый iPhone выпущенный в марте 2016 года на той же самой платформе, что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
Screen not firing up
Phone came into the shop yesterday and this could be bad
Unit seems to have no power and will not turn on
1. Tested Battery over half charged
2. Plug in charge cable Phone gets slightly warm after about 10mins charge
(normal and charging)
3. Changed Screen no change
4. Plugged into itunes itunes sees phone
5. Put on another screen (both new) no change
6. Checked main board no damage to connectors
Starting to get worried for this phone, anyone have any ideas ??
Cheers
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
have you tried power cycling the phone? pop the battery and press the power button then plug back in.
if that doesn't work you could have blown the backlight chip by changing screen without disconnecting the battery first.
rip the backlight off a working screen and shine a torch behind the lcd to confirm
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
Thanks for the quick answer, I new as soon as I posted this I should have mention rule 101. Isolate power source. Sorry.
Yes I did isolate the power source and i have disconnected the battery and retried to start the phone to no avail
из
no problem, next step is to tear the black backlight off the back of the screen you won't damage anything so don't be scared then you will be left with the lcd with you can shine a torch thru and see if the lcd is working
из
Ripped a good screen off one and no back light. Looking more like the Backlight circuit problem
из
Наиболее полезный ответ
If iTunes recognizes your device and multiple screens don't work, then check the LCD with a flash light. If you see a dim image, then it sounds to me like you have a blown backlight circuit on the logic board. It's usually the filter but it can also be the rest of the circuit.
It's either the screen or the backlight circuit on the logic board. If you have access to a known-good screen, try that first. Otherwise, you will need to find a reputable shop that does micro-soldering.
Счет 5
2 Комментариев:
Thank you for your time, great help. That is why I like this forum. Working alone in a shop you don't always have the answers and it is great to "put it out there" To this great pool of knowledge
Thank you again
из
My pleasure!
if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
из
Добавьте свой ответ
charlieclemett буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 167
