My epson L220 printer : ink and paper red light blinking alternately
This problem occur when my friend refilled the ink.
Это хороший вопрос?
Это хороший вопрос?
Your printer waste ink counter overflow, you have to reset your printer waste ink counters.
Please try with this solution: https://resetkey.net/epson-l220-resetter...
Был ли этот ответ полезен?
epson printer l220 paper and ink blinking
i dont know how to do please help me
@maricel.cutie Step 1: Download WIC Reset Tool here: https://resetkey.net/download ,
Step 2: Connect printer and computer by USB Cable, computer connect to the Internet.
Step 3: Reset Epson L220 printer's waste ink counter by follow this guide: https://resetkey.net/epson-l220-resetter... - FREE to reset Waste ink counters to 90%
Watch this video:
Ink and paper lights blinking alternately means that your internal “waste ink pads” are full and need resetting/cleaning out.
Check your Epson Status Monitor (on PC) for any error messages - if it says “service required” or “…end of service life” then it’s the waste pads.
You’ll need to reset the internal counter using WIC Reset tool (a reset key can be had very cheaply).
Then you’ll need to either:
a) clean or replace the internal pads (usually just a case of removing one or two screws on the recent Epsons)
b) extend a piece of tubing out of the printer and directing all waste ink to an external container, such as a bottle or tub.
Tested, tried and successful. You can reset your waste ink counter but you have to avoid waste ink pad overflow.
I found this video, helpful for me https://www.youtube.com/watch?v=rb3CIhXZ...
I found this post on ifixit: How to Hack Epson L200's Waste Ink Pad
Good luck!
Erm... this us the exact same thing I wrote, is it not?
За последние 24часов: 17
За последние 7 дней: 114
За последние 30 дней: 565
За всё время: 112,827
11 Комментариев
i need its solution....
из Pravat dangol
my printer is alarm red light blink
из Somu Biswas
please answer
из Somu Biswas
Signal red light and paper jam
из Somu Biswas
My printer is telling me that a printer's ink pad is at the end
из Gift Rahman
Показать 6 больше комментариев
