LCD and Screen replacement
I removed the gold strip next to the battery above the home button flex when removing the LCD digitizer after front glass removal. Can I continue with the repair or is it now repairable?
Это хороший вопрос?
Это хороший вопрос?
The best way to find out is to test the new screen and see if it's responsive. I'm not entirely sure if it's just a heat dissipation piece or part of the sensor for the touch screen.
I know the back of the new LCD should have the film attached as well, so I can only assume that it's a heat dissipation piece.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 152
1 Комментарий
You should upload a picture of it then others can help you.
из Mandy
