Can you replace my OS framework or replace motherboard?
Samsung update has corrupted my android OS and I need it fixed or motherboard replaced
Это хороший вопрос?
Это хороший вопрос?
You will need to reflash Samsung official firmware on the phone. Since the phone is in bricked state you will not be able to backup the phone.
http://updato.com/how-to/how-to-install-...
Follow this guide and make sure you try flashing home_csc first instead of CSC to avoid factory reset unless it's needed.
You will need to hold volume down + power + home until you get the download mode prompt screen
Same keys, volume up if you want to boot recovery.
Same keys volume down if you want to force shut off phone when holding it for longer.
Был ли этот ответ полезен?
Hey man, if your OS has gotten corrupted I would consider a factory reset through recovery mode.
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 188
2 Комментариев
@noronicscodez how did the update corrupt your OS?
из oldturkey03
have you tried a factory reset ?
из Jimfixer
