Hi @mmir ,
Post some close up pictures showing the capacitor with the information on it.
That way people will know for sure what type it is. Also if you can place a ruler next to it in the picture or give the measurements for it. That will also help.
Here's how .Adding images to an existing question
Alternatively you can search on some electronic components websites and see if you can locate it yourself.
Here are just two:
http://www.farnell.com/
https://www.mouser.com/Passive-Component...
Hi @mmir ,
Thank you for the pictures they were very helpful. (and very good too! ;-) )
You need to find a radial can, SMD (surface mounted device) 220uF 16V aluminium electrolytic capacitor. I couldn't find out what ddt meant. perhaps it is a manufacturer's code of some sort.
You need to check a few things with the capacitors that are available in the link I provided:
1. Make sure that you can buy just 1 as some have a minimum number of either 5 or 10 that you have to order. (unless you are happy to buy 5 that is)
2. Check the data sheet associated with the capacitor (data sheet link next to Adobe icon near picture of each capacitor) that the dimensions are the same (or nearly the same as the one you have). Most are but I haven't checked all of them.
I looked on Ebay but they either didn't have the specified capacitance or you needed to order 100+ .
Alternatively if you click on this link and select your preferred country and then type in Electrolytic capacitor SMD 220uF 16V in the search box on the page you should get results more suitable to you. No doubt check for the same things as mentioned above
Hopefully this is of some help.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите «Прикрепить комментарий к этому сообщению», чтобы переместить его.
1 Комментарий
Will the speaker work without the mentioned capacitor?
из Stefan Vella
