Samsung Galaxy Note 4 — это сотовый смартфон, выпущенный в октябре 2014 года. Номер модели Galaxy Note 4 — SM-N910, а для американских вариантов — SM-N910A, SM-N910T, SM-N910V или SM-N910R4.
Note 4 No Sign of Life
I've been trying to get this Galaxy Note 4 working, and it is showing no signs of life. When it is plugged in, the notification light does not show. I have tried every combination of buttons I've heard, and it won't do anything. It doesn't vibrate, the notification light does not turn on, and the screen does not turn on.
I tested for voltage on the battery terminals with the battery out and the charger connected, and it shows 4.19 volts.
I have replaced the battery with a known working battery, and it did not act any differently.
I'm pretty certain at this point that it's a hardware issue, but what can I check? Being that I'm getting voltage at the battery, I know the charging port is working properly. The only other thing I can think of is something on the motherboard is bad, but of course if anyone has any idea, I'd love to hear them!
Updated with pictures...
I just removed the motherboard for simplicity in the picture.
Tested the battery again... It is showing 3.79V. Still no sign of life. Where is PWR7000? And the other things, for that matter.
Update 2: I removed the cover, everything looks to be alright. The scratch on it is just from a screwdriver... my mistake!
Это хороший вопрос?
Счет 2
2 Комментариев
PWR7000 is your power switch
из Поделиться
I got that, I was just trying to see where the power switch leads in order to check for obvious damage.
Post updated again.
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
@boostedmoose115 follow the troubleshooting flowchart
If you need to find the components etc. post a couple of images of your motherboard. Use this guide Добавление изображений к существующему вопросу for that
Update (01/20/2018)
for U7000 and most of the components you'll have to remove the EMI shield as pointed out
Был ли этот ответ полезен?
Счет 2
6 Комментариев:
Chances are power management of needs to be replaced.
из Поделиться
Thank you for posting, I'll double check the battery voltage and go over the rest of the flow chart at some point today and report back.
из Поделиться
Updated.....
из Поделиться
Would the V_BAT voltage be the battery voltage? And what is C7128, and how do I check it? I apologize for all the questions, but I can't find anything telling me what these things are. The the wiring diagrams either don't say anything or it's just impossible to see what they say.
из Поделиться
I personally don't think note 4s are worth repairing for power ic issues. Too easy to crack the screen on open and already tried replacing multiple chips with no success.
Their prone to going bad on this model again anyway.
из Поделиться
Показать ещё 1 комментарий
Добавьте свой ответ
Alex буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 21
За все время: 6,203
