Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
Dead iPhone 3GS. Any reasons?
I tried to charge my iPhone 3GS and while it was charging. It turned itself off, The battery was at 98% when it turned itself off. It didn't show any error. Just turned off while I was browsing in Safari. I unplugged the charger. Which is the original Apple charger. But after that phone became really hot. I left the phone for about 2 hours when I came back it wasn't hot anymore but it won't turn on. I tried holding the Home + Power button. Tried to get it into DFU mode. Plugging into PC or charger doesn't work either. Can you guys tell me what may be wrong with it? Is it the logic board or the battery?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
try first the battery....... change it.. if not
its on the motherboard... on pm ic.. was shorted.. i encounter that problem but theres no solution... beacuse theres no availabale in the market..
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I think I have a power IC for iPhone 3GS on eBay. http://cgi.ebay.com/iPhone-3GS-Main-Powe... I would try the battery first. If not then I would get the service for power IC.
из
Наиболее полезный ответ
mystikal, I would start with the battery. It is not very expensive toreplace and readily available. Once you have the new battery installed and should still have problems, at least you know that the battery is good. Makes it easier for trouble shooting. iPhone 3GS Battery Replacement and the battery is available here iPhone 3GS Battery GoodLuck and let us know.
iPhone 3GS Battery Изображение
Продукт
iPhone 3GS Battery
$14.99
Оценка 1
3 Комментариев:
It turns out it's the power IC. I have given it to a service centre for diagnostics though. Let's hope it gets fixed. Thanx a lot for your response!
из
Good that you got it figured out.Lets hope the cost for repair is economically feasible. Good Luck.
из
Thanx. It turns out it WAS the power IC after all. Got it repaired for 100$. Phone is working fine now :)
из
Добавьте свой ответ
mystikal будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 3,315
