The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
59вопросов Показать все
What can I do to fix a pink/purple screen with a white vertical line?
About a month ago, I dropped my phone killed my screen and I had it fixed.
Last night while I was charging my phone, it fell!
When I picked it up the first thing I noticed is that it had a vertical white line that ran from top to bottom and the area where the line was located could no longer work.
Then I noticed some pink/purplish lines running in all directions on the screen!
Now the whole screen is a pinkish purplish colour and the part of the screen where the white line was originally located has started to turn black, it is slowly progressing and I am guessing that by the end of the day my screen will be completely black.
Also, my screen isn't broken!
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
Only solution is to replace the screen again.
Был ли этот ответ полезен?
Оценка 4
  • sounds like you were playing a video.if you switch tabs during a tab many times it will come.remember,it might be 4 times
  • it could be screen problem
  • joining a meeting+playing a video ,it will come like that
Оценка 0
1 Комментарий:
you`r screen will also off,please off it and on it again
из
Добавьте свой ответ
thea sku будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 28
За всё время: 9,632
