Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89вопросов Показать все
My PSP GO was bricked!
What can i do to repair it(Blue screen of Death)?
Flash0 / font accidentally deleted :(
Это хороший вопрос?
Оценка 2
1 Комментарий
Does it just boot to a blue screen?
из
Добавить комментарий
3 Ответов
Выбранное решение
Make sure your charger is plugged in and press the O button to repair and restore default settings.
Был ли этот ответ полезен?
Оценка 2
Наиболее полезный ответ
If you are actually running a CFW on the PSP, than you should be able to boot it into recovery mode holding the right bumper, while turning it on. If you were using a HEN, and don't have a CFW installed, then you are kinda stuck with a brick, and might want to consider selling it for parts.
*EDIT* If you are using Custom FirmWare (CFW) and can boot the PSP into recovery mode, using the method above, and you can scroll over to Advanced>Toggle USB (flash0), connect it to your computer via USB, and replace the font file you deleted.
Оценка 3
1 Комментарий:
CFW = Custom Firmware - HEN = Homebrew ENabler: Basically if you are running stock firmware you are not able to get around Sony's limitations it is a paper weight. Unless you have CSW, Flash0 / font accidentally deleted :( = paper weight
из
I concur with ABCellars.
To clear BSOD try pressing o
The PSP will then attempt to repair itself by re--installing default settings to flash.
Оценка 1
Добавьте свой ответ
LORD MK будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 37
За всё время: 13,360
