The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108вопросов Показать все
My samsung tablet 10.1 is freezing sometimes
my samsung tablet 10.1 keeps freezing and also has like a oil slick on screen. when i charge it, it has a x instead of a lighting strike and powers up slow. my guarante has run out and it only occasionaly freezes. what should i do as i dont want it to stop working altogether so how do i know if its the battery screen or motherboard that needs fixing and how do i fix and also can samsung still fix as its a secondhand device and how would i get hold of them, generally there is no problem except freezing every now and then. what should i do? Please help!
Update (03/18/2018)
Ive done clear cache partition i also tryed to take picture of oil slick mark but it doesnt show up properly so what do i do to get rid of it as i am not aware of it getting wet as i am a secondhand user so i dont lnow wether before it had i know it hasnt since ive had it
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Try restoring it in Odin. Might fix the freezing
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
As for the freezing you can try wiping the cashe partition this video shows how on most samsung tabs If this brings no joy you may need to do a complete factory reset. this will cause a lose of all data so remember to back up what you want off the tab before preforming the factory reset . As for the oil stain on the screen could you please post a picture so we can see what you mean This link shows how to add a photo to this question . Was the tablet dropped or has it got wet . Knowing this can also help in fixing it. Hope this helps
Оценка 3
Добавьте свой ответ
selina будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 4,254
