Samsung Wf330anb drum seems too low in rear
I have a Wf330anb Samsung washer. It started making as loud whine at the end of the spin cycle. Eventually would not balance with 2 minutes left. Have changed the rear dampeners because the drum looks much lower than it should be. The springs look brand new. Still looks too low. Could the bearings make it look this way?
I have pics but do not know how to attach.
Thanks for your time
Update (04/19/2018)
I have taken the rotor off. It looks good and the bearings "felt" good. I do not mind changing the bearings but is there a way to check the bearings before taking the shaft completely out?
Thanks
Это хороший вопрос?
1 Комментарий
Hi @fishguy1 ,
Here you go.
Adding images to an existing question
из jayeff
