How will you set up 24 fps in eos m 50
i tried but canon eos m 50 showing ony 25 fps or 60 fps i was not able to adjust on 24 fps
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Выбранное решение
Hi,
Looking at the user guide it appears as though you have to set the camera up for NTSC 4K or Full HD to get the 24fps.
(Click on images to enlarge for better viewing)
Был ли этот ответ полезен?
Счет 2
If you're looking to shoot 24p footage, you'll first need to be make sure you're set to NTSC as PAL does not have options for 24p, only 25 and 50p.
Please take some pictures and post them: Adding images to an existing question
Счет 1
Hey I had this problem too. The correct answer is to put the camera into ‘Manual Exposure’ mode from the dial. Click the menu button on the camera and go to function settings. Go the the number 3 on the horizontal menu and ‘Video System’ should be the first option. From there change the mode from PAL to NTSC and when you go back into video mode on the camera you will have the correct frame rates!
Hope that helps.
Счет 1
Добавьте свой ответ
John Thelapuram буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 5,317
