20 Amp Fuse on Kohler engine
Where is the 20 amp fuse located on the TroyBilt Super Bronco, using the Kohler Courage 20 motor?
Это хороший вопрос?
Это хороший вопрос?
@grayone there are at least 2 of those. One is from the solenoid to the switch and one from the battery to the headlight. If it is the one for the starter follow the red wire from the solenoid. The fuse is an inline fuse and that way you can trace it by the wire. Same for the headlight fuse.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 18
За последние 30 дней: 28
За все время: 3,763
