2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774вопросов Показать все
Black screen is seen with flashlight and works with external display
Hello good morning, I just turned on my Macbook pro 15" 2015 model: A1398.
I was reneging for a while until I could see with a flashlight the log in screen, logged in and put in an hdmi cable, and everything is working except the screen that is still the same, in fact I'm sending this message from the macbook.
You know what it might be?
New Photos:
This is the code you asked me for: 820-5482-A
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Выбранное решение
'''++Facundo Panizza++'''  you do want to go ahead and check the parts on your board. You need to get to the logicboard so follow this guide to get there.Use this guide MacBook Pro 15" Retina Display Mid 2015 Logic Board Replacement for that. Check the board and see if it has an 820-XXXX number on it. this is important since there are a few variations. Take some good pictures of your board etc. and post those with your question. That will allow us to see what you see. Use this guide Adding images to an existing question for that. Check the display cable to ensure that it is properly seated and that the connector is not showing any damage on the pins. Then you want to start by checking the backlight fuse for continuity and check if you have power going to it. This will be tricky since you are going to power the computer on. Do not shorten other components out while testing it. Let us know what you find.
If unsure of doing any of this contact the experts @reecee and @tcrs_circuit to see what their take is on this and if they can help you further.
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
MacBook Pro 15" Retina Display Mid 2015 Logic Board Изображение
Инструкция
Сложность:
Сложно
1 - 3 hours
Был ли этот ответ полезен?
Оценка 3
6 Комментариев:
I'm sorry for the long delay, I leave the data you had asked me hopefully serve something, not get to see any corrosion, just a few stains near the load pin
из
I think the 9700 fuse is not walking, because I used the multimeter and gives me 0, to use it with other fuses, gives me varied numbers
из
Facundo Panizza do not worry about any numbers. Just check it for continuity https://www.swe-check.com.au/pages/learn...
из
Well, it didn't give 1, say 0.00.
из
okay sounds like a bad fuse. Replace it and check the circuit since something caused the fuse to blow. Check your connector make sure there is no corrosion or damage on it.
из
Показать 1 больше комментариев
You’ll need to check the backlight fuse and you might need a new backlight LED driver chip as these tend to fail.
Оценка 1
Hi Facundo,
To me it sounds like your backlight went out on your Macbook. I would look into a possible replacement, but before you order another one. I would check into seeing if it just came unplugged or the cable for it went bad. That way you do not waste your money on another screen if that was not the problem.
Best Regards,
Drew.
Оценка -1
1 Комментарий:
@takkaz what kind of backlight would you purchase for this and which cable may have gone bad?
из
Screen light is burned out or inverter is out.
Will need repairing by a technician.
Оценка -1
4 Комментариев:
@charlied139 where is the inverter for this model and which screen light may have burned out? Can you elaborate on your answer?
из
@oldturkey03 Nice question =;)
из
@arbaman thank you for your support and for our great participation on our forum. You are an asset to the community!
из
@oldturkey03 Thanks a lot for the kind words, I really appreciate :))
из
Добавьте свой ответ
Facundo Panizza будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 2,079
