Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Home Button Failure after Display Assembly Replacement
After a successful replacement of the glass on an iPad mini 3, the undamaged home button is not functioning when pressed. There are no errors reported on start-up. Given these circumstances, does this mean the connector on the logic board has been damaged? Again there are no signs of damage that I can detect.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Assuming you don’t have a teeny microtear in the flex then the MOST LIKELY problem is a parts problem on the screen. These are notoriously bad. Definitely make sure to test home button function before sealing it up.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Michael Scott буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 84
