Известная как "PS2", это игровая консоль шестого поколения, впервые выпущенная Sony в Японии в марте 2000 года. В США она появилась позднее в 2000 году как SCPH-30000. В России PlayStation 2 начала продаваться 7 ноября 2002 года. Для ремонта этого устройства требуются только обычные инструменты, но он может оказаться непростым.
PS2 disc read error
Hello everyone, i have problem with my PS2, it stopped reading discs, this happened when i was playing Tekken 5 (original disc) and while playing, i proceeded to the next stage and then just stopped at the character pictures, i waited for long time and nothing and so i restarted my PS2 and it didn't read the disc, i tried another original disc and nothing, i tried a blue disc (the other ones were silver) and it worked but it stucked at the first text screen, so that means it still can read blue discs but will stuck at the first loading
I tried all my original DVDs and nothing, i opened the PS2 and tried to see if i can fix it, there wasn't a lot of dusts and cleaned the laser eye (the thing that the red laser comes out from) and nothing, i tried turn the two white gears and still nothing
but i noticed something, when i put a silver disc the laser eye starts going up and down inside and makes the clicking sound, a soft one so i think this could lead me to my main problem
My model number is SCPH-50004, very similar to the SCPH-50001
So any help please ?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
The raising and falling of the lens is an attempt to read the disk, the laser is trying to focus. This is normal. Theclick is when it returns to the “down” position.
If you have cleaned the lens using alcohol and a cotton swab and the behavior continues, it is time to replace the laser assembly. This does happen after a long while.
Dan
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Can i clean it with water ? and is it only laser lens or can it be another thing ?
из
Добавьте свой ответ
Khalil Mokhtar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 2,324
