The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
Battery temperature too high
Got a new battery in my note 5. A few days later, it's telling me charging paused, battery temperature too high. Battery temperature is normal though.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
Probably the battery is faulty giving incorrect battery temperature information, I usually see the battery temperature too low message meaning liquid damage near the charging port area (where the thermistor component is).
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Thank you for your input. The battery is new and original. I recently (a few days) replaced it. The notification disappeared now. Battery is charging, but not exceeding 67%.
из
This might be a long shot but is the phone up to date for software updates (Android OS updates) in settings?
из
Thanks Ben. OS system up to date. I am noticing now they it is charging sometimes, And charging is paused sometimes. Can't quite figure out when and why. Today when it paused, i pulled the cable and blew some air in the hole. It restarted charging. Can't figure why either. Is charging overt 67% now, 82 and going up.
из
Добавьте свой ответ
E B буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 3,407
