Asus ROG Strix GL702VM-BHI7N09 — это игровой компьютер, выпущенный компанией Asus в январе 2017 года.
What's wrong with the GPU?
Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.
I’ve tried a fresh install of Windows, a different drive that I know is fine, different NVIDIA drivers. So I’ve narrowed it down to the GPU.
I’ve done some runs of Furmark, and each time, when it gets to >75C it usually blue screens or freezes with blocks/stripes of green/white/purple, and if it doesn’t do that on its own, a reasonable tap on the keyboard where the GPU chip is causes it.
Is this a sign that it needs BGA reballing by a repair shop, or is it a more serious less-repairable issue?
Thanks in advance for any help :)
Это хороший вопрос?
Счет 0
1 Комментарий
Joe McKinnon try some GPU throttling and see if it makes a difference. Root cause for this is poor airflow to keep things cool. https://rog.asus.com/forum/showthread.ph...
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Yep, “Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.” thats a sign of a dying/deadGPU. If the GPU in this machine is modular and can be replaced it is a simple and relatively inexpensive fix if you have the right part. However, if the GPU is soldered to the motherboard that would require a motherboard replacement which is by far not the easiest thing to replace and it will be costly.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Joe McKinnon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 398
