How do I get a pice of paper out of the disc slot
I brought my friend over to help me sort out with this game because it was freezing every time I go on it and he put a pice of paper in it and now I can’t get it out
Это хороший вопрос?
Это хороший вопрос?
Hi @tombaker ,
Here’s a link to the ifixit Xbox One Optical Drive Replacement guide.
Once you have removed the ODD you should be able to carefully open the ODD case and remove the piece of paper and then re-assemble it again.
Был ли этот ответ полезен?
You could try vacuum.. Should pick up a piece of paper.
um disasemble the system i dont know the peice of paper must be in the disc drive
It is in the disc drive
what you want to do is disesemble your system try finding a tutoreal or whatever find the disc drive part of your console and gently remove the piece of paper without damaging any componets if you cant do that then try contacting microsoft for the issue
get a disc and put a double piece of tape on the disc and put the disc in about half way then pull it out and the paper should come out
have you tested this ?
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 25
За всё время: 1,174
1 Комментарий
I sad cause i put money in my xbox and an
making weird noises
из radom anime kid weeb
