After battery replacement trackpad does not click.
Hi!
I've went through tutorial to replace battery in MacBook Pro 2014 15” that can be found here.
MacBook Pro 15" Retina Display Mid 2014 Battery Replacement
After reassembly the trackpad is not clicking. As of now I set the Tap To Click setting, but when it comes to selecting text or working with photoshop, it's kind of pain.
The only solution would be the tension screw, that is placed bellow battery (that I've currently installed.. that's no good, don't want to mess with battery since I would probably ruin it on the way out)
Do I have any other options? I've also done the reset of SMC and PRAM. Which is not helping, I am assuming the tension screw is the solution here.
Anyway you might add to the tutorial that users should check the trackpad clickability before putting new battery with glue into place.
Anyway I am happy with the product and delivery and everything, you guys are excellent!
Thanks for any kind of help.
Это хороший вопрос?
