Выпущенный в сентябре 2013 года, Gigabyte P34G представляет собой 14-дюймовый игровой ноутбук с процессором Intel® Core™ i7-4700HQ 4-го поколения (2,4–3,4 ГГц).
Battery replacement doesn't work
With new battery replacement the icon indicate 100% full charge and when i unplug the charger the pc shutdown!
My charger specification is : output 19.5V ; 7.7A
My battery specification is : Battery Volt: 10.8/11.1V / Battery Capacity: 4300mAh/47.73Wh
My PC is : P34GV2
I buy it here:
http://www.laptop-battery.us/gncc30-giga...
This is the second battery replacement i do because the first was doing the same thing and it was returned
How its possible and what can i do?
Это хороший вопрос?
Счет 0
1 Комментарий:
Hello,
now the situation has change…
I have two os in my laptop linux and windows. The first test i do it was to test with my principal os Linux and the result is my first message here.
So i tried to test it on windows and on it, the battery work good with a good charge and discharge ect, but when i boot in linux the laptop won’t boot or run without ac charger and when i unplugged it the, os poweroff suddendly…and the same happen with a live cd.
I don’t understand where is the problem, if is the battery a lot exotical discount fabrication and also that explain the poor compatibility? or there is parameter in bios or others things that i don’t know?…
из
Добавить комментарий
3 Ответов
“With new battery replacement the icon indicate 100% full charge and when i unplug the charger the pc shutdown!”
2 reasons why you may be experiencing this issue:
  1. both the batteries you purchased my have been faulty.
  2. there is an issue with the motherboard getting power from the battery.
Possible solutions:
  1. replace battery again, if that doesn’t work then
  2. repair the motherboard (although sourcing information and parts may be difficult) or
  3. replace the motherboard
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Hello,
из
your must buy a defective item,for your Gigabyte P34GV2 battery please look at our link:
http://www.laptopower.com/GNC-C30?search...
we have 1 year warranty
thanks
Счет 0
If it has one, disconnect the power button board and/or the charging port board, clean the contacts and then reconnect it.
Счет 0
Добавьте свой ответ
Ki Ko буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 29
За все время: 636
