Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Cracked Case?
Near the thumb-scoop there appears to be a small crack running parallel to the case (follows the curve of the scoop) and is about the length of the trackpad button. It is only small but is there something I can do without replacing the entire case?
Это хороший вопрос?
Счет 1
Добавить комментарий
4 Ответов
Выбранное решение
You have to show it to your local Apple Service Provider. I some cases Apple will repair the MacBook.
- shurai
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
It's not under warranty though
из
I see, so the top case actually has a crack in it. For a complete fix you will need to replace this. You can use this guide to carry it out.
Счет 2
2 Комментариев:
I'd rather not pay $169 USD and just keep it as it is. It doesn't bother me so i will just leave it
из
I agree, maybe you could try shurai's suggestion?
из
If the crack is on the keyboard then they'll repair it at no cost. They said it is recognized as a design flaw. However if the crack is anywhere else then you'll have to pay for it
Счет 0
I have the same problem with my black macbook, I use black electrical tape to cover it, it's the perfect color, if you have a white macbook you could use white electrical tape.
Счет 0
Добавьте свой ответ
AussieMac буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,724
