Умная колонка Amazon Echo 2nd Generation была выпущена 31 октября 2017 года.
My aux port doesn't work
I haven’t gotten quality speakers until a year later so the warrant just ended. I plugged in the aux cable for the first time and it doesn’t make any sound. It doesn’t really click in and instead just kinda sits there. It’s making a weak connection because the echo does recognize it’s connected if wiggled in the right position because it stops playing music at that moment. I think the aux port broke loose and needs to be repositioned or something similar. Is it possible to access the bottom of the echo and repair the aux port?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
It seems to me that in the Alexa app, then the device’s settings, you can change how the AUX port operates between in and output settings. As for the port being “loose” or out of line, it is soldered to the board making a replacement far more difficult. Not impossible, but my two cents would be to look for a replacement “AMP Board”. Hope this helps!
Был ли этот ответ полезен?
Счет 1
2nd gen is only aux out not an input. Introduced on 3rd gen
Счет 0
Добавьте свой ответ
quinntensity буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 30
За всё время: 2,773
