Выпущенный в 2012 году, Asus N76VZ представляет собой 17-дюймовый ноутбук с разрешением экрана 1600x900 или 1920x1080 пикселей. Он оснащен процессором Intel Core i7 3-го поколения и видеокартой Nvidia.
Why can't remove battery
Hello
I am trying to remove battery on Notebook Asus N76V, but I think it have problem with the slider lock because he is on the wrong position and now it is very hard to remove it, I tried a little force to remove it but I wasn’t able to do it… I searched many solution but I didn’t found the solution.
Edit: it is Asus N76VJ but I think it’s the same way to remove battery.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
It’s likely that the slider to unlock the battery is broken. First try sliding it to the unlocked position and force the battery out. There isn’t much you can do other than replacing the bottom case. I’ve found though that a lot of times if I force it out, it will come out with little damage.
Был ли этот ответ полезен?
Счет 3
with flat head screwdriver,
start to lift battery pack from back ( furthest away from battery open slider )
start to lever from right or left ,,, lever from either corner
This worked for me and i did no damage to mechanism
operate lever and apply some silicon spray
Счет 1
1 Комментарий:
This was actually helpful!
I used a plastic pick and started wiggling and sliding.
I spent more than 30 minutes trying before seeing this tip, and I was so happy that I didn't break anything lol
Thanks
из
Добавьте свой ответ
Mickael Gomes буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 26
За все время: 1,424
