Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432вопросов Показать все
Bright flash on shut down...
Hi, I recently installed an SSD and additional 16Gb of RAM to my 2011 iMac (specs below). My sytem is running beautifully however I have noticed when I select ‘Shut Down’ and the computer is closing down, there is a bright flash from inside as it finally closes. I can’t say that I’ve noticed it before. Any ideas what’s happening there..?
iMac Intel 21.5" EMC 2428Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Это хороший вопрос?
Оценка 0
2 Комментариев:
How did you install the SSD replacing your HDD or adding it as a second drive?
из
OPTIONS
Hi Dan,
I added it as a second drive and installed a new operating system on it. I can still see and use the old drive
из
Добавить комментарий
1 ответ
This iMac specifically has GPU issues. Not saying that that is what is happening but you could be on the verge of having a GPU issue. Things that might have started that is if you installed new SSD without setting up someway to keep it cool like Mac’s fan control or installing the special cable that monitors the SSD TEMP and connects it the Logic Board.
My guess is you GPU could be on it’s way out. Do an easy restore of just your OS and see if the issue is fixed. Maybe the install you did on the new SSD is corrupt in some way. Worth a try to get rid of variables.
Update (03/12/2019)
Hi. To reinstall the operating system really all you have to do is hold down the command key and the R key To restart in recovery mode. Can you have the option to re-install whatever operating system is installed on your Mac. This will only re-install the base operating system and leave all of your files and applications in tact. Sometimes in order for your applications to work properly you might need to do a couple of updates after you re-install a base operating system
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Can I do an uninstall of the system on the original hard drive? How do I restore my current SSD operating system without having to replace other software?
Thanks.
из
The restore of the OS only does the OS and leaves the Applications and user files alone
из
Добавьте свой ответ
Paul-e Thomas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 65
