Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
288вопросов Показать все
Why will my wii read a game disc, but a wii u will?
I recently bought a used copy of smash bros brawl, when I put it in my wii, it says it cannot read it. All my other games work just fine and the brawl disc was in good condition I tried putting the disc in my brother’s wii u, and it worked! I have been hacking the wii using the sd card, so maybe thats the problem? No idea, please help.
Это хороший вопрос?
Оценка 2
3 Комментариев
Are you sure it's not a Wii U game?
из
yes, it is smash bros brawl which is only on the wii
из
It could have been the fact that you attempted to hack it, and caused the disc reader and other programs to misbehave.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
This is a pretty common issue on older Wiis with dual layer disc games. Not many Wii games use dual layer discs but Super Smash Bros. Brawl does, so it’s likely that your other games you’ve tested aren’t, and that’s why they work but this one doesn’t.
Here’s a list of Wii games that use a dual layer disc. If you own any of these games you could try testing them as well.
This issue does mean your DVD drive/laser will need to be either cleaned or replaced. If you’re feeling up for it, you could follow this guide to remove the laser, and clean it with a method like this (see step 3). Otherwise, if the cleaning doesn’t work, the laser will need to be replaced completely using the aforementioned guide and a new laser. However, the easier method would be to replace the entire drive.
Nintendo Wii DVD Drive Lens Изображение
Продукт
$34.99
Инструкция
Nintendo Wii DVD Drive Lens Replacement
Сложность:
Модерировать
1 - 2 hours
Nintendo Wii DVD Drive Изображение
Инструкция
Nintendo Wii DVD Drive Replacement
Сложность:
Модерировать
1 - 2 hours
Philips DVP642 Изображение
Инструкция
Laser Lens Cleaning
Сложность:
Легко
10 minutes
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Randomperson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 23
За всё время: 887
