Released on July 28, 2014, the Samsung Galaxy S5 mini is a cell phone that features an 8 MP rear camera, 720p display, fingerprint scanner, and water resistance. It has a larger display, increased battery life, and an updated camera from its older brother, the Galaxy S5.
30вопросов Показать все
Is it necessary to clean inside of my phone if it is fall into toilet?
My mobile phone was dropped in toilet for 12 hours. I dried my phone. But i think there is dust inside. But my phone is running very well. I want to know if the dust is harmful for the future?
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Hi @fixzahid ,
Water resistant doesn't necessarily mean waterproof.
The specs state that it can withstand water up to 1 metre for 30 minutes, which is a bit different to 12 hours submerged!
Whilst there are no problems for now that is not to say that they won't appear in the near future.
Just so that you are aware of this
Personally I would open it up to inspect it but I'm just cautious around electronics and water especially if the device is not new.
Are there any minute cracks in the case or flaws in the seal due to normal activity over time which may have compromised its’ water resistant integrity for example?
Here’s a link to the ifixit Samsung Galaxy S5 Mini guide, if you decide to do this
This link may also be of some help. Electronics Water Damage
Hopefully you also cleaned the outside of the phone appropriately given where it was found submerged and also how the phone is used ;-)
Был ли этот ответ полезен?
Оценка 2
If your phone is running very well, then there is no need to fix anything for now. Samsung Galaxy S5 phones are water-resistant, so being submerged underwater probably didn’t cause significant damage.
Оценка 1
2 Комментариев:
I feared about the dust,not the water. Will dust create any problem?
из
The mechanism in the phone that blocks the water will most likely block the dust as well.
из
Yes its highly recommended you can run in to a lot of issues from it.
If I helped you please accept my answerHow To Accept an Answer
Оценка 0
Добавьте свой ответ
Zahidul Nahid будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 13
За всё время: 94
