Руководства по ремонту, разборке и диагностике Apple iPad 6-го поколения, доступного в версиях с Wi-Fi и сотовой связью, с объемом памяти 32 или 128 ГБ. Выпущен в марте 2018 года. Модели A1893 и A1954. Оснащен 9,7-дюймовым дисплеем Retina и 64-битным процессором A10 Fusion.
Home Button doesn't work after iPad 6 screen replacement
I have been repairing electronics for years. Never had any issues with iPads until recently, home buttons stop working after digitizer replacement. There is no damage to the home button or the cable or anywhere. Anyone else having this problem?
Or have found a solution?
Это хороший вопрос?
Счет 3
Добавить комментарий
2 Ответов
It could just be an alignment issue, is the metal part of the home button bracket (which is the contact for the button) aligned with the center receiver of the home button?
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
No, it even makes the clicking sound and everything. Even when I install a new button, still doesn't work.
из
The clicking sound is not an indicator of anything. Try to align it better with the bracket. I had this issue as well last week.
из
Look at the back of the home button. There should be a tiny black dot in the center of the switch. If all you see is amber that dot has fallen of and the switch will not work when installed.
Счет 0
Добавьте свой ответ
minnabeezy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 29
За всё время: 1,284
