Released in March 2017, the Moto G5 includes a 13.0 megapixel rear camera, a 5 inch screen with a 1920 x 1080 resolution, and the Android 7.0 (Nougat) operating system. Identifiable by the model numbers XT1675 and XT1676
27вопросов Показать все
Managed to knock component off when opening
When I was prying the motherboard cover off due to an accident with water I stupidly managed to knock a small component off (see attached image). I’m not sure what it is but I imagine it’s a standoff/ground of some sort?
What is it? Can I fix it back on? I’m not sure what it was fixed on with but there is little residue.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Those are soldered to the board. If you have soldered before you can solder that back on.
I think that one is a grounding pin that contacts to the back cover housing of the phone.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
james будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 46
