Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797вопросов Показать все
Logic board compatibility 30GB in 60GB
I have an Ipod Classic 5th Gen A1136 and I pulled the battery connector from the logic board while removing the cable. That’s what you get for rushing :) I am wondering if a logic board from the 30GB Ipod of the same generation will fit into mine ? I believe that the 30 and 60GB use the same early board and are compatible but prefer to check before purchasing the 30GB one. Thanks in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@pedro147
yes it does. no issues there.
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Man that was quick, I hadn't even logged out yet @oldturkey03 :) I was just reading about some HDD upgrades as well and you have contributed some valuable answers there too. I thank you and have a great weekend.
из
@oldturkey03 if you are still around, I was just thinking that seeing as the Ipod I might buy appears to have a better LCD screen than mine, can I just put my 60GB HDD straight into it please ? I would assume so from what I have read here. Thanks.
из
@pedro147 yes you can. If your original iPod was a 60GB you are okay, if it was a 30GB you need a thinner battery (the one for the 30GB is thinner so stick with it)
из
Добавьте свой ответ
Peter Newman будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 240
