Tear down videos on YouTube or ifixit are the best to look for,period.
Sometimes there is tape over random things that can be torn. But there is a flex cable(basically a bunch of flexible wires in one ribbon cable). There is a flex cable on the bottom right. I’ve done my brother’s iPad mini 2 digitizer replacement. It is very easy to tear it. If you upload a clear picture I can tell you if it is the flex or not. But if it is,you need to replace the digitizer,which requires disconnecting the battery,removing the silver plate that the lcd sits in,and disconnecting the flex fables. This is tedious and you have to be careful. Trust me,watch YouTube videos and look at the ifixit tear down guides before attempting this.
ifixit parts are typically good quality. I’d recommend ordering a digitizer from them and replacing it…
If the touch screen doesn’t work anymore,but the lcd still shows the apple logo and image,etc,then it’s obviously the flex cable for the digitizer that was torn.
Youre lucky if it was the digitizer that tore. It is much cheaper(like $30 sometimes) versus an lcd being at least least around $100,usually more that it’s worth.
I can help you more if needed.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
2 Комментариев
Maybe a teardown would show the component in question?
iPad Mini 2nd Generation
Could also attach photo's to aid other participants here identify the component in question:
Adding images to an existing question
из prop man
That is the whole cable for the touch screen and home button. Screen will need to be replaced.
из Ben
