The Sony α6500 can be identified by model ILCE-6500. It's a mirrorless, digital E-mount camera with APS-C Sensor. The Sony α6500 was released in November of 2016.
12вопросов Показать все
Sony 6500 Base Damaged
The Base of my Sony 6500 was damaged in that a tripod screw broke inside the camera body and now the camera cannot be used on a tripod as the screw cannot be removed. Is it possible to have that bottom OR the complete outer camera replaced
Это хороший вопрос?
Оценка 0
1 Комментарий
I'm not sure how different the models are but here is a disassembly video of the A6000. Hope it helps!
https://www.youtube.com/watch?v=y3CCJtD0...
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hey Douglas,
I had a similar thing happen with my a6000 a while ago. You could opt to replace the outer housing, but depending on how well the tripod screw is lodged, it could be removable with no disassembly. I covered the bottom with painting tape and made a hole in the tape where the screw is is. I then used a small bolt about the size of the hole, put a small dab of glue on it, and let it set. Once it set for a long time and hardened, I simply twisted it out.
Hope that works for you, best of luck!
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Douglas Quick будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 250
